Track control bush query
  • keithborgars
    • 17
    Help or Info. I have just fitted replacement Poly bushes to the Anti-Roll bar/ Track-control arm, and the only instructions are to make sure all parts are clean and free of rust and paint. Looking at the bushes I would have thought flat retaining washers should have been fitted, not the old Sierra convex retaining washers (for the old rubber bushes) but none were supplied with the kit. My query is, is it OK to fit the old washers and if not, is it local manufacture for the replacement?
    Keith YKC Roadster (Sierra)
    • 1648
    Re: Track control bush query
    Hi Keith.
    If you are talking Sierra TCA bushes then have a look at my post #18 on the following link:
    The correct washers are the O/E Ford ones are as follows:
    ARB Washer / Front
    6172539
    Dished / Black
    ARB Washer / Rear
    6172540
    Flat /Green
    These are a larger diameter than those supplied with the aftermarket bush kits. Peter
    • keithborgars
      • 17
      Thanks Peter for your reply - most helpful. I should have delved deeper into previous threads on suspensions but one day I will possibly get used to computers! Keith
