Windscreen Surround
  • bryannewell
    • 331
    Windscreen Surround
    Hi folks
    How do you remove the Windscreen surround from a Cabrio?
    I have the two piece sort which has a screw either side of the centre join and a rivet at each end down below dash,is that all there is?
    Bryan
  • CosworthCabrioLee
    • 924
    Re: Windscreen Surround
    Yes Bryan that is correct but I would imagine it still be stuck with widescreen sealant as it goes on when the screen is still drying. What's the reason for removal ?
    • bryannewell
      • 331
      Hi Lee
      Thanks for responding
      The reasons I wish to remove it are to polish it up properly and to tidy up the inner windscreen frame as previous owner has covered this in vinyl but it is coming adrift
      Do you think it will be difficult/worth it to remove?
      Bryan
      • CosworthCabrioLee
        • 924
        Is it stainless or alloy ?? if it was me I would polish it in situ, just be very carefull you dont break the screen, if your fitting a new screen it does not matter
        • bryannewell
          • 331
          Lee
          It is the ally one!
          Perhaps I'll see what Ican do with it in situ!
          Thanks for the advice
          Bryan
          • CosworthCabrioLee
            • 924
            I would cover the interior from splash and get a polishing mop on it, once you are happy with the finish then give the car a good wash.
            • bryannewell
              • 331
              Lee
              Thanks for the tip I'll give it a go
