Cabrio Front Suspension
  • Chimaera
    • Jun 2012
    • 8
    Hi
    Can anyone tell me what this stub axle is from, I need top and bottom ball joints so would like to identify the parts.
    The car is a Mk1 Cabrio
    Thanks
  • CABRIOBOB
    • 478
    Re: Cabrio Front Suspension
    Chimaera
    Its from a Ford Sierra. You would need to buy a complete track control arm for the lower joint, there are always plenty on ebay.
    • Chimaera
      • Jun 2012
      • 8
      Hi Cabriobob
      Thanks for the reply
      I had a feeling it might bea Ford Sierra, however the top ball joint appears to be fitted to the modified upright, if I'm right have you any idea what it is from ?
      Thanks
      • CABRIOBOB
        • 478
        My info tells me it is a Metro top ball joint QH1060 5 OR S !!. Need to get some else to confirm before buying.
        Just found some more info, it is QH1060S or Motoquip VSJ 473 fitted to the Metro from 1994 onwards as have a larger dia taper pin.
        • Chimaera
          • Jun 2012
          • 8
          hi cabriobob
          Thanks for the help, do you know if this info is in the Cabrio Assembly Manual from the club
          • CABRIOBOB
            • 478
            Chimaera
            More info and the details are in the Cabrio build manual.
            Ball Joint : - QUINTON HAZEL
            QSJ1060S
            PART DESCRIPTION : BALL JOINT Autogem AM113
            PART DIMENSIONS (MM) : 50 x 90 x 120 Delphi TC301
            POSITION ON CAR : - FAI Autoparts SS170
            POSITION ON CAR : FRONT UPPER LEFT OR RIGHT Falcon FJ499
            Firstline FBJ 5151
            Lucas TRW JBJ264
            MOOG RO-BJ-3562
            Motaquip VSJ473
            • Chimaera
              • Jun 2012
              • 8
              Thanks Cabriobob
              Help really appreciated I'll order a build manual tomorrow
              • Peterx
                • 361
                Hi Chimaera,
                if you are in the UK, I currently have one QUINTON HAZEL QSJ1060S for sale on eBay.
                http://www.ebay.co.uk/itm/1809137352...#ht_500wt_1413
                If that link doesn't work it's ebay item number
                180913735217
                ...peter
                • Chimaera
                  • Jun 2012
                  • 8
                  Hi Peterx
                  Thanks for the offer, I needed two and got them locally
                    Originally posted by Chimaera View Post
                    Thanks Cabriobob
                    Hi Chimaera
                    I've just come back of holiday, so did not see your post until today. Have you sourced a build manual?
                    I have it in electronic format, which is much better than the original, and can send you a cd copy if you'd like one?
