I am experiencing a problem with my car.
The engine is a 1.8 Zetec with fuel injection and an Omex 600 ECU. also installed is LPG. The LPG system takes sensor readings from the ECU so it shares the various sensors however the LPG has its own injectors.
On petrol the engine almost cuts out after about a half mile but I have always been able to get home on what feels like 2 cylinders, all plugs are burning correctly and all are the same. In desperation I have checked the fuel supply side and fitted a new Sytec high flow filter element and another after the pump before the fuel rail. A while ago I fitted new plugs and leads.
On LPG the car appears to behave itself.
My thinking is the only device not being shared are the petrol injectors, these all appear to be OK but as a precaution I have sent them away for checking and cleaning if necessary.
Any thoughts?
Thanks Roger
Any thoughts?
Thanks Roger
