Cabrio towbar
    Cabrio towbar
    cabrio towbar required please
  • bryannewell
    • 331
    Re: Cabrio towbar
    Hi dogon!
    I have one recently removed from my cabrio which I don't plan to re-fit so up for grabs if you wish?
    01823 601416
    Bryan
    • bryannewell
      • 331
      Re: Cabrio towbar
      Hi Alan
      Sorry I keep missing your calls,I have been a bit busy at work with the weather of late!
      Next time you ring and have to leave a message if you leave your number I will call you back!!
      Bryan
        Re: Cabrio towbar
        Bryan
        My phone number is 01332 753000
        • bryannewell
          • 331
          Re: Cabrio towbar
          Alan
          Parcel due to be picked up by city link tomorrow!
          Bryan
            • 1236
            Re: Cabrio towbar
            This information may be a little late, or hopefully you are aware. The tubes that form the bumper brackets were a smaller dia on early cars. However If they are larger on the tow bracket Than the brackets perhaps you could fit sleeves. Hopefully both cars are similar. Sorry I did not pick up on this thread sooner.
            • bryannewell
              • 331
              Re: Cabrio towbar
              Danny
              Thanks for the info, I did not know that and I guess nor did Alan,but already on the way!!
              Alan
              If no good for you let me know
              Bryan
              • dave_kitson
                • 269
                Re: Cabrio towbar
                Hi - Cabrio towbars come in 2 shapes, the later ones were modified to clear the opening boot. If you have no boot, either will be ok. I found mine would chatter on the struts when towing, which was a little disconcerting. I cured it with a simple strip of steel bent at one end to fix on the towball bolt, and anchored at the other end on the diff mounting bolt. Have fun! Dave
