Re: Mike's Cabrio Build
Mike,
"If your using a single led bulb it needs to be connected to the indicator feed wire and to earth before the switch, it should not cause the indicators to flash as it cannot draw enough current to cause the relay to operate, if its a "normal" bulb you connect each side to the indicators out put (left and right, one wire to each) if its a LED light and your connecting it after the indicator switch then the connecting wires for L+R need to be joined using diodes on each wire to the LED +ve connection.." Locost site
It has just worked fine for me with 'normal bulbs.
Mike,
