Boot Lid Rear Closure?
    Sealing My Boot?
    Can anyone post a photo of how their Cabrio/Hunter closes off the rear edge of their boot, to stop water coming in, please?
    I know the attached exaggerates the problem, as the boot lid fills a significant part of the square cut out as it is closed, but on its own it is nowhere near water tight.
    Is it better to try to make a seal around the square edge to the boot lid? - difficult against the rough underside of the GRP lid?
    Or is it better to take an impervious membrane and attach it to this square cut out, and then take it down to where the boot lid hinge is to create a permanet physical barrier?
    Photos would be a big help, please?
    • 1644
    Re: Boot Lid Rear Closure?
    Hi Mike. My Hunter has a flexible rubberised sheet stretched across that area. There seems to be a metal strip attached across the boot hinge bar to trap the rear edge of the fabric. Then the fabric is folded forwards over this to conceal it. The sides are glued down onto the floor ply and the carpet then fits over this. At the front edge an alloy strip goes over the carpet with the seal fabric underneath it all. On mine the floor slot is cut wider than yours, more in line with the boot lid edge from memory. I will post some pics later as I have to go out for a while. Peter.
      • 2796
      Mike, mine's the same as Peters - surprise.
      I don't have any pics but can take some if Peter cannot. My cutout, again as Peters, is somewhat wider than yours
      The material is almost like a heavy blackout cloth (if you're old enough to remember that ) A narrow ally strip is pop rivetted
      to the boot lid, and a wider one is screwed onto the ply floor
      Cheers DC
      BTW Peter, what's your chassis number ? I have T4 132.
        • 1644
        Photos as promised are below. Peter.
          Excellent Peter, thank you for the photos. Many many thanks.
          Just looking at your photos, you certainly will not have any issues with your new tank straps!
            • 1644
            No probs. My 1955 classic car was built by Rootes so over engineering comes to me automatically! Peter.
              • 1644
              Cheers DC
              Hi Dave. Curiously it is T4152 ! Peter.
                [ATTACH]3246[/ATTACH]
                [ATTACH]3247[/ATTACH]
                [ATTACH]3248[/ATTACH]
                [ATTACH]3249[/ATTACH]
                [ATTACH]3250[/ATTACH]
                [ATTACH]3251[/ATTACH]
                [ATTACH]3252[/ATTACH]
                Does anyone know what this material is?
                I've tried thin rubber sheet, and not received the response I expected?
                  • 1644
                  Hi Mike. Have a look at this link:
                  Maybe they can help? Peter.
                    Thanks Peter.
                    They passed me on to RS Components who sell small quantities, so will collect some tomorrow.
                      • 1644
                      Thanks Peter.
                      Splendid! Peter.
