To narrow the prop tunnel I've been thinking that a fixed diff (like Triumph or Sierra) would advantageous. Many years ago I had a Volvo 340 that handled nice and had a De Dion rear axle. Such an axle would be easy to adapt to a Marina based as it mounts on leaf springs. No problem narrowing if necessary. The advantage would be less unsprung weight plus PCD change to 4 x 100mm. Panhard rod can be incorporated at the same time. Would give big choice of diff ratios and even LSD option. Obviously custom drive shafts would be needed. Volvo diff is a transaxle so couldn't be used.
This is what the Volvo item looks like, minus drive shafts -
Anyone already tried this ?
Paul H
Paul H
