Fuel cap size
  • steppenwolf 1936
    • Apr 2014
    • 6
    Fuel cap size
    Hi help needed for a replacement fuel cap
    Reading previous threads on subject a Escort and Cortina sized cap seemed correct for my car which is a 1984 Roadster so bought one of E bay and its way too large, just measured the filler neck and it seems to be a 1 1/2 inch inside diameter filler
    any ideas as to the original make this fuel tank would have come from originally
    Car came with a locking fuel cap in plastic that P.O had broken to remove as no key came with it and it also leaks!
    • 2447
    Re: Fuel cap size
    If yours is a mk 2 i.e. marina based Marlin then the fuel tank would have been from a Mk1/Mk2 van or estate Escort.
    If not then someone will be along with the relevant information.
      Re: Fuel cap size
      Most roadsters used the Mk 1/2 Escort van/estate tank but your car is a bit of a one off with the MGB running gear. Either way the builder may have used the neck from any suitable vehicle. Try posting a picture and see if anyone can suggest its origins. The alternative is to look at Holdens or Car builder solutions and replace the whole neck and cap. Or find a friendly breakers yard to have a wander around to find one that fits.
      • steppenwolf 1936
        • Apr 2014
        • 6
        Re: Fuel cap size
        Thanks
        Good call, it turns out to be a MGB /Midget/ Mini sized filler.
        Should have guessed!
