ticked a few jobs off the list
    • 930
    First I attacked the fuel pump. I took it off, removed it and refitted it with some PTFE tape. Then I had to fix the wiring because the fuse holder that I'd used fell apart when I disconnected the fuel pump. Having sorted out the fuel system, hopefully, I went on to replace the cam belt. I was worried about it because it was 30 years old, even though it wasn't showing it's age I still thought it should be changed as a precaution. Having got her running again I reset the timing as I hadn't adjusted it after fitting the electronic powerspark system. Well that was a busy day, and now I'm as stiff as an old boot!
    Re: ticked a few jobs off the list
    Originally posted by andyf View Post
    ...and now I'm as stiff as an old boot!
    That's what's worrying me now I have a car I'll be tempted to work on it!
      Hi David
      PM me as I am in High Wycombe, maybe we could meet up for a chat?
        Yes good idea, I'm just across the West Wycombe Road from you in Sands. Seen you at Kop Hill Climb a few times, I was the dayglo vested steward shouting at you as you left a couple of years back
          Hi David
          Unable to PM you, have you turned that off on your profile?
          David.
            which david are you there are a number?
              You were right it was turned off.
              I have now turned it on so you should be able to PM me now.
                • 930
                That's the joy of owning a Marlin, not only do you get to drive it but you get to repair it too
