Hi to all,
I'm new to the Club and have just purchased a 1984 Marlin. Its fitted with an A series of Marina descent although I have no idea of the age of the engine. I have a couple of mechanical problems to sort out which will hopefully have the car running really well again and hopefully the Forum contributors can help me here. Both the carb (an SU HS) and the distributor have pretty much had it.The Carb linkages are really worn, vacuum advance has been disconnected and plugged and when reconnected idle is 1500 to 200 rpm and impossible to adjust lower. With the vacuum outlet plugged and sealed rpm is unstable at 1200-1500. I'm pretty much blaming the Carb but am open to suggestions. Points are fine and static timing seems ok.
I contacted Burlen to ask about reconditioning the SU but they advise a 16 week lead time? Does anyone have a good one that is surplus to their requirements?
Any help, greatly appreciated.
Scotty
Scotty
