Marina 1.3 exhaust downpipe
    • 2445
    Hi
    Can anyone take a picture of their exhaust downpipe coming from the manifold and exiting the engine bay side.
    I know I have asked this before and it will be a little bit of an issue trying to get in there to take a picture but I would be forever thankful.
    Many thanks.
  • FranklinLeicester
    • 380
    Re: Marina 1.3 exhaust downpipe
    Hi Adrian,
    Just read your request. I'll send you a pic tomorrow. Mine has the standard Marina cast manifold with a tailor-made stainless downpipe exiting through the inner wing just above the chassis. I think this is the original way they were done..
    Franklin.
    Franklin, Leicester
      • 2445
      Many thanks Franklin
      • ruby131
        • 163
        Hi Adrian, mine is as near to original. I cut the downpipe about 2 ins from the flange then fitted stainless flexible which as Franklin says passes through the bonnet side panel just above the chassis rail. This then fits to an original stainless box, I twisted the flex until it tightened on to the downpipe section the clamped with a stainless u clamp. Works fine.
          • 2445
          Hiya
          Can you do me a picture if its not to much trouble.
          Happy to be PM'd
          • FranklinLeicester
            • 380
            Here are my pics. As you say, not easy to photograph but hope it helps. I'll be at Stoneleigh on Sunday. If you're there find Q880YAW and I'll not be far away. Franklin.
            Franklin, Leicester
            • FranklinLeicester
              • 380
              Here is no 3 for what it's worth. Franklin.
              Franklin, Leicester
                • 2445
                Thanks Franklin
                That does help.
                See you at Stoneleigh
                  I have one of these which I will have in my boot to give to DC - if you want a look at it before I hand it over
                    • 2445
                    Is it a Stainless Steel one?
                      • 2445
                      Yep It would be good to check it out.
                      • john cole77
                        • 22
                        Hi Adrian
                        Just been in the garage and taken a few pictures that may be of assistance.
                        The system is the original Stainless one supplied by Marlin.
                        Fingers crossed the pictures appear, don't post very often
                        • john cole77
                          • 22
                          Success!!!
                          If you need any more pics let me know
                          John
                            • 2445
                            Hi John
                            That's great.
                            Was the downpipe supplied by Marlin?
                            I have exactly the same Stainless silencer.
                            Are you restoring yours as well?
                            Looks as though you are about the same stage as me.
                            Regards Adrian
                            • mark westbrookwhite
                              • 146
                              John do you really have a chequer plated garage floor? that is so cool.
                              Mark.
