Torsion bar
  • stephenlilley
    • 102
    Torsion bar
    I am thinking of fitting Avo coil overs to my Roadster. Has anyone ever disconnected or removed the torsion bar as it may be to stiff with the coil overs?
    Re: Torsion bar
    Did you ever decide which of the two sizes of torsion bar you have fitted? The larger diameter ones will be too stiff for a roadster. Equally tyre pressures and sidewall profile have a lot to do with handling issues.
    Torsion bars have been removed completely and replaced with coil overs, a quick search of the forum will find some pictures.
    Personally I think it is a bit of a gamble, not so much from the mechanical point of view, but the selection of the spring. It's position is far from vertical making any calculations a best estimate, and you may end up worse off than you already are.
      Re: Torsion bar
      Just found the right post with pictures
      here or there
      • stephenlilley
        • 102
        Re: Torsion bar
        Thanks for your valued advice Steve. Lots to think about.
