Needle Numbers
  • stephenlilley
    • 102
    Needle Numbers
    Can anyone tell me what needles I have in my HS4 carbs. They are stamped ABA, I cant find any reference to them.
    Thanks
    Steve Lilley
  • dbazdavies
    • 409
    Re: Needle Numbers
    The Worlds Sole Manufacturer of Original SU Carburetters, Fuel Pumps and Spares.
    they should offer a correct needle for what ever engine mods you have !!
    • dbazdavies
      • 409
      Re: Needle Numbers
      ABA is a good needle number for the HS4 carb
      click on HS4 carb.. on the top line
      • stephenlilley
        • 102
        Re: Needle Numbers
        Thanks for your replies chaps. The reason I ask is I have just dyno tested my Roadster and it shows it is running lean from around 40mph. I am thinking of using a size 6 or 7 to enrich it. Any thoughts?
        Thanks.
          • 709
          Re: Needle Numbers
          Depends on state of tune.
          Fitting a K&N or other freeflow filter will usually mean a richer needle is required over standard to compensate for improved airflow...IIRC for an MGB-spec 18v engine running K&N with no other mods then AAA needles were a recommended upgrade.
          • stephenlilley
            • 102
            Re: Needle Numbers
            Thanks for that info, Will look at the spec of the AAAs. Engine is bog standard apart from Stubby stacks fitted which massively improved airflow.
              Re: Needle Numbers
              AAA should be a good place to start - going much richer may throw up further problems. Check tappets are accurate too!
              • stephenlilley
                • 102
                Re: Needle Numbers
                Thanks Cameron, very informative graph.
                  Re: Needle Numbers
                  I have scans of SU needle data, but not yet uploaded. I always found it interesting that a 1.3 mini used the same needles as a 1.8 TC!
                  • dbazdavies
                    • 409
                    Re: Needle Numbers
                    I used to ring Burthem and they told me what to use !!
                    • stephenlilley
                      • 102
                      Re: Needle Numbers
                      Thanks for the further info chaps, I have not heard of Burthem, could you post the phone number?
                        Re: Needle Numbers
                        Burlen ltd
                        Spitfire House, Castle Road, Salisbury, Wiltshire SP1 3SA
                        01722 412500
                        they will be able to tell you everything you need to know and probably more beside
                          Re: Needle Numbers
                          I would have whoever did your rolling road fit the jets and retest - I had mine done and even after the operator rejetced it he took another hour of adjsutments to get the mixture righ over the whole rev range - it was not just fit and problem solved.
