Mk2 marina steering wheel cowl
    • 2447
    Hi all
    Other than a Marina cowl (which are like rocking horse p**) what have people used?
    I realise I will have to adapt whatever is used.
    • 929
    Re: Mk2 marina steering wheel cowl
    I never bothered. If I was going to rewire mine I'd go the hotrod route and use an after market indicator stalk and buttons for everything else...
      my old roadster had a leathercloth cover - bit like a gear lever gaitor.
      • Peterx
        • 361
        Is this any good?
          • 2447
          Peter mmmm could be adapted.
          Cameron I will think about that one.
          I only have the one stalk to worry about on the left.
            • 2792
            You could always be patient and keep watching ebay, it worked for me.
            Rgds DC
              • 685
              Would an MGB/ Midget one fit? LHD one so that the stalk opening is on the correct side. www.sussexclassiccar.co.uk/shop... about half way down the page.
                Rgds DC
                If Adrian only needs one stalk, a Marina one would still need modifying to fill the second hole. Not to mention, quite probably turning upside down.
                  • 2447
                  Now that's the baby, absolutely fantastic and little or no modification.
                    • 2447
                    Agreed Steve but I will go down the mg midget route.
                    Thanks
                      • 2447
                      Rgds DC
                      CheersDC but as you will see from the post below I will go down th MG route.
                        • 685
                        Just check whether the screws come with the cowl; you may need to buy them separately.
                          • 2447
                          Good call
                          Once again many thanks
