Classic headlamp switch
    • 2445
    Here we go again.
    Would like to use this classic pull pull headlamp switch.
    Unfortunately they do not have a wiring diagram.
    Given to me by a deceased friend.
    They have a stamp on them which is JK107.
    When I look them up they on Google they are still available but only from China.
    Ebay item number 191867814807
    Any ideas as to what terminal does what?
    I only have a supply (brown), side light (red) and a dip switch (blue) cables available and obviously an earth.
    Flasher is via a multi function stalk.
    Re: Classic headlamp switch
    You need to check the rating of this switch. If it's only 5a, that's just one headlamp, not a pair. Lucas smoke will be released unles you fit a couple of relays.
      • 929
      Oh... releasing the blue smoke... fun!
        • 2445
        Hmmm checked fuse and it has a rating of 20amps ???
          Ebay description from the part number you supplied, or fuse! Another dilemma. Is there a marking on the switch body? Being Chinese I doubt it is really what it claims. Relays are always a good solution to the potential of fire!
          Smoke testing is not the preferred method, but if you use it, please take a video, share it with us, and buy some Lucas smoke to top the wiring up afterward. I have never seen that last process carried out, I am curious to see if it works.
          This is also a general comment to those who rely on the standard Marina stalks. They have tiny contact points, and are a b*****d to repair, putting less current through them, has to be a long term solution.
