Midget 13" rostyle wheels
  • djj_engineer
    • 405
    I have a need of 4 off or 6 off 13" rostyle or steel wheels to suit a Marina roadster, with or without tyres
    Re: Midget 13" rostyle wheels
    DJ
    MG midget wheels wont fit Marina axles of either saloon or the half ton van as they are 4" PCD.
    What you need are either Marina or Triumph Herald/Spitfire/Vitesse or GT6 wheels, which can range from 3½ to 5 inch widths.
    Some 1800 TC Marinas were fitted with rostyles
      As Ben says. 1800TC Marina wheels are the ones to hunt for...
        There is a terrific write up in the latest Morris Marina Owners Club Mag, that detailed many of the 3.75” PCD wheels, from several suppliers. Worth a read!
        As always, standard Marina wheels have a 1/2” offset but depending on your tyre manufacturer/profile etc. You take your chances taking care of the clearances available on the front suspension, the rear is pretty much wide open.
        Spacers are dodgy as the standard studs are short, and they really need to be concentric, not so easy on a Marina saloon hub.
