De Lorien Marlin
    • 2447
    De Lorien Marlin
    OK, it took some 240 grit paper, pre-paint and WD40 to get the brushed look.
    Three coats of clear lacquer and that's a finish I could live with.
    Decision made, I will do all the aluminium myself.
    Finished item on right.
    • 2447
    Re: De Lorien Marlin
    Used a Scotchbrite pad and, in my opinion, is even better.
    The centre one has the reflections of the trees.
    • meverett
      • 662
      Good idea Adrian but your grass needs cutting. 😀
        • 2447
        Cheaky bugger
        Originally posted by meverett View Post
        Good idea Adrian but your grass needs cutting. ������
          Maybe one of the robotic mowers so that the human can get on wiyh more fulfilling tasks. Will lacquer bond to ally without etch primer? If I don't use etch primer on the Landrover the paint will flake off.
          • meverett
            • 662
            Wonder what finish a fine grit flap sanding wheel on a drill would give with light use.
              • 2447
              It appears to, I am going to leave the test pieces outside to see what happens.
              I'll let you know.
                • 2447
                Might work, I'll give it a try and let you know the outcome.
                A
                [ATTACH]10983[/ATTACH]
                • A_Hogg
                  • 337
                  I thought everything fell off Land Rovers!
                    Bits only fall off because they rattle. If the bolts are tight they don't. It is difficult to bolt paint on, you need big washers!
