My Marina based Roadster I converted to used coilovers on the front, and one of the shocks is end of life.
So the time has come to replace and improve on the current setup. I could do with more travel as Im very close to the bumpstops, I'm more than happy with the spring rate and the ride it gives is a good balance between sport and comfort I'm using 120 Lb springs with about 1/2 inch of pre load. The big question is if i get a shock that is one inch shorter but fit the same spring but with 1 inch more preload will I end up at the same ride height and same ride comfort balance but one inch more travel left in the shock, hope this makes sense as it works in my head.
What do people think
