Re: Coil overs
The bracket that mounts the inner end of the lower arm is independant to the torsion bar. The lower arm is in two parts, a large cast bit and a pressed steel bit that are sandwiched together. The cast arm has a splined hole, one half of which contains a splined bolt which fixes the arm to the chassis mount, passing through a large rubber bush. The torsion bar is just fitted in the "other half" of the splined hole. An odd arranagement in a rather odd suspension setup. IMHO :-). But it means the torsion bar can be removed independently of the suspension arm.
Cheers, Robin
PS - would still like details of the revised damper bracket :-)
Originally posted by dogoncrazy
View Post
Cheers, Robin
