Stronger/more durable metro ball joints for E30 based Sportster?
  • Patrick
    • 463
    Has anyone found a source of ball joints that are not made of cheese? I've been through quite a lot of them, and again this year the MOT tester has noticed one of them starting to go, not enough for a warning yet but I'm going to change it anyway.
    I've been getting these GSJ268: https://www.minispares.com/product/C...%20to%20search
    http://www.modelog.co.uk/
    http://www.mustang67.co.uk/
  • stevepritch
    • Sep 2017
    • 290
    Re: Stronger/more durable metro ball joints for E30 based Sportster?
    If its E30 based are the suspension/steering components not from the donor car?
    • Patrick
      • 463
      Not much E30 left on the Sportster's front suspension, only the bottom of the shock mount/spindle/hub/brakes. Even the steering rack is not BMW, I believe it's a ford part. The shock mount is cut and a thread welded in - the thread fits a metro balljoint which connects to the upper wishbone. The lower wish bone also mounts a metro ball joint. A lot of the E30 Sportster is based on the ford version which some tweaks.
