size of battery in A/H
    • 2445
    Re: size of battery in A/H
    You can get a Powervamp 680 for £109, an equivalent from Halford will cost you £100.
    Not much difference and the Powervamp gave my passenger their legroom back.
    It also meant I gained room in the engine compartment.
    Originally posted by martinclan56 View Post
    The cranking amps is limited by the batteries internal resistance and is independent of, although related to, its amp hour capacity. I guess Oddesy use a technology that means the internal resistance is kept low. Which explains the cost....
    Cheers Robin
    • angusgrooby
      • 124
      I have the varley red top 25 battery (the same as the 680 but slightly higher amp hour) on my pinto berly and I feel sometimes it struggles with turning it over for any length of time this may be because I have a mechanical fuel pump but still feel it slows down to quickly but on my zetec roadster it is great.
      To sumerise I would go for the next size up if it's going on a 2.0 pinto.
      Angus
