Stripping alloy wheels
  • Gareth
    • 502
    Hi, I'm looking for some recommendations for stripping the lacquer off the alloy wheels on the Roadster with a view to repainting them.
    I've seen one called Rustoleum Aircraft remover on YouTube but doesn't seem available over here. Never had any luck with Nitromoors. Anyone tried something else. It's a lockdown job I just fancy having a go at.
    Cheers Gareth
    • 2790
    Re: Stripping alloy wheels
    Oh boy will you ever need patience to do that.
    I gave up and had mine blasted, even then it took ages to get them prepped for spraying
      To be honest I didn't even contemplate doing it my self but took a set of wheels to a specialist refurbisher. Cost an arm and two legs though.
        Can't you use GENTLE heat to start with?
        • Ye Ol Ripper
          • May 2016
          • 297
          There is a place in the midlands that charges £30 /wheel for strip refurb paint. would you like me to look for their details ?
            • 2447
            I would as the cheapest round my area is £60 per wheel.
              Frost Strip Gel
              • Ye Ol Ripper
                • May 2016
                • 297
                People have used them on another car forum I am on and with good results, If the tyres off the rim its £20 /wheel
                  • 2447
                  Cheers.
                  • Gareth
                    • 502
                    Cheers, but it would be a bit far. There's places around Chester that can do it if I give up doing myself. Thanks anyway!
                    • Gareth
                      • 502
                      Something else I'm doing is changing the old Mountney steering wheel to a 9 hole Astali wheel. Thought I'd just check I can get the old wheel off as the steering nut could be done up tight and a puller might be needed to free the boss off the splines and taper. Took off the horn button cap to reveal that the big nut was finger tight and no lock washer fitted and the wheel just lifted off once the nut removed! It's been like that since I got the car and passed numerous MOT's and never given a hint of being loose! Could have ended in tears...suggest you check yours!
                      Gareth
                      • Gareth
                        • 502
                        Well, that's the wheels done, windscreen frame done and a new steering wheel as well. She scrubs up well!
                          • 2790
                          A nice shiny day and a nice shiny car as well....must be summer soon
                            That is a stunning machine...
                            • lizbillings
                              • 828
                              Wow! Amazing!
                              Well done
                              Liz
