New to Kit Cars, so bought two....
    Re: New to Kit Cars, so bought two....
    A servo maybe? Kit car wiring can be fun for the second owner, my Roadster had the loom stuffed behind the dash and I ended up cutting a couple of feet off every wire. One at a time, to make sure they joined up right. At least yours look as if they were marked. At this rate, you will be back on the road by the weekend!
      • 685
      Girling super vac brake servo, something like this:
      This is in a Marina but gives you the idea:
      Might be a challenge to find one in good working order.
      • ian944
        • Aug 2021
        • 35
        Managed to get a few hours the weekend to add a MGB indicator stalk and complete the wiring for Headlights, indicators and horn.
        Added Main beam warning and indicator tell tales on the dash.
        Spent a small fortune on Ebay and have lots of little bits heading my way.
        Next big job is the brakes, thanks guys for the pictures of what the missing servo should look like.
        I'm going to dismantle the existing servo delete kit and see what i need to do to get the brakes to work.
        Good news is its a single pipe system so as simple as it can get ( I like simple).
        there should be at least one MGBGTV8 master cylinder in the shed so might look to rigging that up, once I have a pedal with more than 2mm of travel and that moves the pads/shoes I'll consider adding a remote servo, but with no weight in the car, it shouldn't need one.
          When my Roadster servo was working, the brakes were ferocious. Now it is disconnected they are still good. With a good push, they will lock up. With the servo, the front would lock up very easily I was thinking of putting a limiter on the front brakes to stop that happening. Just disconnecting the servo vacuum pipe did it instead.
          • ian944
            • Aug 2021
            • 35
            #20
            Another weekend and I'm still going through the boxes of bits included with the cars.
            Unfolding this pile of stuff, resulted in three roofs, six doors and two rain covers, all of various condition from brand new to very tired and "crispy"
            Working out which set was from which car we got this
            Surely this gap cant be correct?
            It needs a good clean and re-blacking plus sealing, but the roof isn't too bad.
            I have also had my little helper giving me a hand all weekend
            Also started trying to do something about the paint, so far its been sanded with 1200 grit
            Next will be 1800 grit and a machine cut and polish.
            Polishing machine is a new toy, never used one before.
            Can anyone recommend a fast cut compound to use after sanding?
