Fuel pump and ignition circuit fuse blowing on mu Cabrio. Help!
  • lizbillings
    • 828
    Re: Fuel pump and ignition circuit fuse blowing on mu Cabrio. Help!
    I am no mechanic, but if it happened in wet weather and OK in dry, there may be wet affecting a relay or other part, especially if it blew a lot of fuses. Liz
    • PeterM
      • Sep 2012
      • 15
      solved!
      The problem was an intermittent fault in the fuel pump.
      I replaced it with a new one and have since done 1500 miles with no further problems.
      I have also added an extra fuse to the part of the common fuel pump + ignition circuit. The new fuse is in the wire to the fuel pump only so if it blows in the future I will know the fault is in the fuel pump part of the circuit.
      Thank you to everyone for your suggestions and words of wisdom!
      Happy marlining
      Peter
