Gentlemen, can a member with a 2000cc Ford Pinto engine in a Triumph front suspension roadster SWB Mk2 advise me of a pundage rating for the front springs. At the moment mine are of an unknown rating and far to stiff. Thanks all
Front Suspension Springs
Re: Front Suspension Springs
If your car is on the road simply take it to a local weighbridge and speak nicely to the operator
You want the front and rear weights
Then calculate the appropriate spring rates
Much like spouting peak horsepower without talking about peak torque or better yet the torque curve, spring rates and damping are rather meaningless without taking your suspension frequency into account.
1 Hz (60 cycles per minute) - is ok for a luxury saloon
2 Hz - 120 cycles per minute is about as high as you want to go with a road car
