Message originally posted by: Tiyen Miller
I'm looking into options for installing a heater into my triumph based roadster. My engine compartment is pretty crowded, however, and I'm not sure what the best apporach might be.
The battery is centrally located in front of the bulkhead (photo), and it seems that that might be a reasonable place to put a polo heater box/blower (they're apparently small - about 8"x8"x11.5"
I can't imagine where I'd put the battery in that case, though. The space above the steering column by the bulkhead only has about 6 inches vertical clearance to the bonnet - could I get some kind of battery in there? I think I mini core would never fit - any suggestions?
Thanks for your ideas in advance!
Cheers,
Ty
I can't imagine where I'd put the battery in that case, though. The space above the steering column by the bulkhead only has about 6 inches vertical clearance to the bonnet - could I get some kind of battery in there? I think I mini core would never fit - any suggestions?Thanks for your ideas in advance!
Cheers,
Ty
