Re: Heater for triumph car - polo perhaps?
Hi Neil,
I actually bought this particular heater from the seller on ebay a few weeks ago (the first one, 290050411246). It seems to be in very good condition, and I look forward to installing it next weekend when I go up to Peterborough to visit my family (and have access to a garage...).
The heater was apparently from a "museum" car, and looks very good, not even any bent matrix fins. However, I've yet to water test it or anything. If I suck (!) on one of the tubes with the valve open, air does flow through with some effort, but it's not "free" at all. Is this normal? What's the best way to test the matrix for soundness? Should I go to a radiator shop, or is there a way to check at home?
The drawings and text in the scans from the manual you'd sent are very clear, and look straightforward enough - thanks!
As I'd mentioned, there seems to be a bit of a clearance issue with the windshield wiper motor, as my motor is mounted closer to the windscreen than is shown in the manual (or on your car). However, it seems that there's only about 1-2cm of interference with the back of the blower housing, and perhaps I can modify the shape of the housing a bit to clear.
Any other points I should be aware of that come quickly to mind? Should the wiring run through a relay, or should the amperage be okay running through a switch on the dash, for example?
Sue - great to be back, thanks. I'm a full time science teacher at south camden community school - nice as it's only 8 mins walk from my house. But I've driven in a few times - the kids all have something to say about the Mr Miller's car!
Best regards,
Ty
Hi Neil,
Best regards,
Ty
