Handbrake lever
    Handbrake lever
    The handbrake lever in my roadster is in EXACTLY the wrong place, just where I want to rest my arm, slap bang in the middle of the transmission tunnel.
    I want to move it to the side of the tunnel and preferrably would like a vertical one.
    Does anyone know anywhere that does one or alternatively a car that has a vertical handbrake
    Re: Handbrake lever
    Didn't Ykc do this on their later Sierra based cars?
      Re: Handbrake lever
      Should have bought a Mk 1 .... My hybrid had a lever mount for a left hand drive kit by error. its fitted inside the left side of the tunnel out of the way, using the Marina lever.
      • beergutdave
        • 47
        Re: Handbrake lever
        My mk1 also has handbrake mounted vertically on left hand side of tunnel. the lever itself is from a Triumph Herald/Spitfire with a bracket welded to the chassis.
        • tymill
          • 130
          Re: Handbrake lever
          My Triumph based car also has the vertical lever mounted on the left side of the tunnel...
            Re: Handbrake lever
            Yes but this wont work on a Mk two as there is no chassis mounting point or chassis section near by. It has to mount on the tunnel itself.
            • kdn17
              • 37
              Re: Handbrake lever
              Hi Don
              Bring a jack to the next SHEB (or come over ot Prestwood) and have a look at the YKC Sierra version, it might be what you want
                Re: Handbrake lever
                Thanks Keith, will do
