Hunter Speedo under reading
  • CABRIOBOB
    • 478
    Re: Hunter Speedo under reading
    I got my gauges last year from www.etbinstruments.com who were good and not badly priced. See pics in my albums.
      • 1644
      Originally posted by chris.cussen View Post
      I believe the Marlin Electronic Speedos are made by ETB.
      Does anyone know who made the original Marlin cable driven speedos like I have? Peter.
        • 1644
        Originally posted by CosworthCabrioLee View Post
        Hi Peter tried to call but no answer, speedograph ritchfield on 0115 926 4235 I have spoken to them £75 for a recalibration if it can be done it all depends once they open it up. If they can't then then you will need a cable gearbox in your cable that is £85 all prices include vat and pp
        Hope this helps
        Lee
        Many thanks Lee and for the phone call. I will talk to thm when I get a minute. Still wondering about a digital look-alike though. Peter.
          I only know the Fordf Rocket box and the type 9. Each can take speedo gears from 21 teeth to 26 teeth wihout changing the worm drive on the GB output shaft (I have four different gears I have been experimenting with). They are very easy to change. Does the Rover box have interchangeable speedo gears? Maybe, if so, this could be a way to go.
          • CosworthCabrioLee
            • 924
            #20
            Hi Peter early cabrio's used Stewart Warner but I think you have Caerbont automotive made in Swansea contact 01639 732200
            • CosworthCabrioLee
              • 924
              #21
              Width Ratio Wheel Diameter
              205 60 15
              Hi Peter a quick check this should be your spped and gearing of the R380 with 3.38 Diff
              5 speed MPH in Gear
              1st 2nd 3rd 4th 5th
              3.3 2.13 1.39 1 0.77
              RPM
              1000 7 10 16 22 28
              1250 8 13 20 27 35
              1500 10 15 23 33 42
              1750 12 18 27 38 49
              2000 13 20 31 43 56
              2250 15 23 35 49 63
              2500 16 26 39 54 71
              2750 18 28 43 60 78
              3000 20 31 47 65 85
              3250 21 33 51 71 92
              3500 23 36 55 76 99
              3750 25 38 59 81 106
              4000 26 41 63 87 113
              4250 28 43 66 92 120
              4500 30 46 70 98 127
              4750 31 48 74 103 134
              With 3.62 Diff
              RPM 1 2 3 4 5
              1000 6 10 15 20 26
              1250 8 12 18 25 33
              1500 9 14 22 30 40
              1750 11 17 26 36 46
              2000 12 19 29 41 53
              2250 14 21 33 46 59
              2500 15 24 36 51 66
              2750 17 26 40 56 72
              3000 18 29 44 61 79
              3250 20 31 47 66 86
              3500 22 33 51 71 92
              3750 23 36 55 76 99
              4000 25 38 58 81 105
              4250 26 40 62 86 112
              4500 28 43 66 91 119
              4750 29 45 69 96 125
              With 3.92 Diff
              RPM 1 2 3 4 5
              1000 6 9 13 19 24
              1250 7 11 17 23 30
              1500 9 13 20 28 36
              1750 10 15 24 33 43
              2000 11 18 27 37 49
              2250 13 20 30 42 55
              2500 14 22 34 47 61
              2750 16 24 37 52 67
              3000 17 26 40 56 73
              3250 18 29 44 61 79
              3500 20 31 47 66 85
              3750 21 33 51 70 91
              4000 23 35 54 75 97
              4250 24 37 57 80 103
              4500 26 40 61 84 109
              4750 27 42 64 89 116
                • 1644
                #22
                Hi Lee. I have 16" wheels. Toyo Proxes T1R 205x55R16 on 61/2" rims. Do you have any tables for that size? Peter.
                  Peter
                  Have a look at this site:
                  Have your tyres fitted at your home, work or a place that is convenient for you. Shop competitively priced tyres at etyres.
                  You can compare your tyre rolling diameter at 632mm to the ones Lee has estimated as 627mm.
                  There is less than 1% difference, so you'll get virtually identical figures.
                    • 1644
                    #24
                    Thanks Mike. I will remove the back cover from the original Quaife diff to check I/D marks on C/Wheel to verify actual ratio when I get a minute. Peter.
