montego efi 2 litre engine.
  • hipster65
    • Jan 2012
    • 9
    i have a 3 leg puller on the crankshaft pulley. it should come off easy, the manual says [if sticky, ease off witha couple of screwdrivers ] the retaining bolt is half screwed in for the puller to bear on, i'm afraid to put on more pressure, might bust something. ???
    • 709
    Re: montego efi 2 litre engine.
    The pulley is screwed onto the toothed cam pulley with 4 screws iirc...and the toothed pulley is keyed onto the crankshaft. So long as the crank pulley is free to separate from the toothed pulley (i.e. the 4 screws are removed) give it some welly. Don't use heat though as you'll melt the rubber vibration damper. Try some firm taps with a rubber mallet while you have some pressure on...
    • hipster65
      • Jan 2012
      • 9
      i removed the center retaining bolt, and a large washer that exposed 3 threaded holes in the pulley that you can poke a screwdriver into for @ an inch or so. i've tried the mallet...i don't see the 4 screws !!! thanks for replying..
        • 709
        Hmmm - my spare Sherpa O2 block (which is supposed to be the same as the Monty) is set up that way...
        If you're sure there isn't anything else attaching it then I guess you'll need to wind up the pressure on the puller..!
          Surely the threaded holes are for inserting bolts to wind up and push the pulley off?? dont know just a suggestion!
          • terryreed1664
            • 257
            Just what I was thinking Ben.
            • hipster65
              • Jan 2012
              • 9
              the engine is i believe, a 20 HP elec/ ign. fuel ingection. i read that there is no manual for this [bugger ]. just a few supplementery notes at the back of my montego owners w man.. the car was built by Geff Ganderton. the pulley in the manual is a 3 spoked open affair, mine is solid. there is very little for the 3 screws to bear on [ see bens [ push the pulley off ] just a slightly domed washer.. as someone said [ilove my MARLIN , it keeps me off the road.. ive replaced the water pump, and need to replace the oil pump but that little circular sod is still hangin' on..
              • hipster65
                • Jan 2012
                • 9
                sometime later 2015.. my marlin experience didn't go too well, 3 years membership, 3 marlins, did @ 50 miles, mechanical lemons.. lost 3 thousand quid.. [ these cars have a known history and are ...etc etc..
