Mk2 wing stays
  • dbazdavies
    • 409
    Re: Mk2 wing stays
    just noticed in the first picture - the top 'wishbone' is at a strange angle pointing upwards ???
      Re: Mk2 wing stays
      It's under load I. E. it's on the ground, is that not right?
        • 930
        Re: Mk2 wing stays
        I think mine are pretty much level to pointing up a little bit
          Re: Mk2 wing stays
          Good spot dbaz.
          I think you may be 1 spline out on the torsion bar setting Adrian.
          Lower arms should be angled down, the upper will be slightly upwards. Build manual has the dimensions to aim for when setting the lower arms.
          Once you get them rough set you can fine-tune using the reaction arm adjuster bolts.
          A good reference is that with the car at rest on its wheels (and at normal weights - i.e. engine/box installed) the steering tie rods should (ideally) be parallel to the ground (or very close to).
          Also check fore/aft e.g. spirit level on the tunnel.
            #20
            Re: Mk2 wing stays
            Originally posted by lil_red_roadster View Post
            Good spot dbaz.
            All
            Thanks for spotting this, it's all obvious now.
            I was foolishly hoping that this was ,at least, the only thing that the previous builder had done correctly.
            Obviously not the case.
            Ho hum, will now take the whole suspension apart and set it up as per instructions.
            A big thank you to all who have contributed to this thread and will post a picture once I have sorted.
            Thank god for the Web site and those that contribute to it.
              #21
              Re: Mk2 wing stays
              All
              Now, which instructions to use?
              The originals, below
              And the updated ones
              Along with the picture below
              I'm leaning towards the latter.
                • 930
                #22
                Re: Mk2 wing stays
                I would set the ride height a little high as the upright tends to make dents in the inner wings...
                  #23
                  Re: Mk2 wing stays
                  Yep that happened with my old roadster.
                  Will check clearence before I tighten up.
                    #24
                    Re: Mk2 wing stays
                    Good spot dbaz.
                    2 hours work and suspension as per instructions.
                    Even had a quick offer up and the inner wing fits.
                    Now just the nearside to do.
                    Cheer guys.
                    • dbazdavies
                      • 409
                      #25
                      Re: Mk2 wing stays
                      You can fine tune the suspension by adjusting the inner torsion bar lever - far too many Marlins are set too high when you look at the pictures !!
                        #26
                        Re: Mk2 wing stays
                        Yep will do oncei have done the nearside.
                        Thanks
                          • 2796
                          #27
                          Re: Mk2 wing stays
                          Result ! Well done sir.
                          Must remember this thread when mine gets down on the ground
                            #28
                            Re: Mk2 wing stays
                            Thanks DC
