MOT
  • peterboat
    • Jun 2016
    • 232
    Re: MOT
    Originally posted by chris_cussen View Post
    I've a three pronged plan to get over the problem:
    1. Talk to Omex: It has a cat and lambda sensor so they may be able to tweak the ECU. I'll take reduced performance over having it parked in a garage.
    2. Find a tame tester, as it was originally built with a 1989 carberettor based engine from a 1989 donor. (MOT rules say if you replace the engine then the test is based on the oldest component, I can argue that since it is on a G plate then altough it was registered in 2009 it is really a 1989 vehicle)
    3. Try to get DVLA to define the emissions on the log book based on the original engine.
    There is one remaining option. Take the engine/gearbox out, scrap the Marlin and try to find a Mk1 or Mk 2 Escort, Midget or MGB to stuff it in.
    I thought the regs were to test as per the engine fitted? or it used to be. I have a 1997 engine fitted in a 1997 car it passes emissions because it was designed right. I dont want to be labelled as a gross polluter and for the sake of our hobby neither should anyone else. Times are changing and my area is a high pollution area, what this means I have yet to find out but it will no doubt mean a restriction on use, I would hate that to be an outright ban
      Re: MOT
      Check the V5c too. Section 3 special note on the front. It may specify the limits for your vehicle.
        Re: MOT
        My note 3 says:
        1. WAS REGISTERED AND/OR USED.
        • peterboat
          • Jun 2016
          • 232
          Re: MOT
          Mine says,
          declared new at first registration
          clearly some like me have to meet 1997 or whatever it was emission regs
          • meverett
            • 662
            #20
            Re: MOT
            My section 3 is blank.
              • 2447
              #21
              Re: MOT
              Latest
              MOT passed.
              Drove it for around 20 miles and then a quick check with my mechanic and home.
              Now before I go to Le Mans Classic
              1. Change coolent
              2. Fit new Alternator
              3. Tidy engine hole
              4. Thrash the hell out of it
              5. Fix things that break
              Etc, etc.
              OK bit reluctant to post this but I had to tell someone.
              The Marlin failed her MOT.
              Believe me I am the happiest person in the world.
              She only failed because the handbrake cable broke and a slight leak from one of the brake pipes.
              My mechanic John is going to sort them for me and I will be driving the beast on Monday.
              I can't
              stop smiling,
              John took me out on a 10 mile run and she doesn't rattle, she steers well, brakes well and sounds absolutely glorious.
              Now for a bottle of wine and try and wipe the smile off my face
              P.S Yahhoo
                • 709
                #22
                Re: MOT
                Well done Adrian - enjoy Le Mans..!
                  Re: MOT
                  GB sticker, Head light converters,breathalyzer gizmo and a reflective jerkin
                    • 2447
                    #24
                    Re: MOT
                    Thanks I will
                      • 2447
                      #25
                      Re: MOT
                      Yep and more.
                      Will be meeting Greg when we are out there.
                        Re: MOT
                        No need for breathtesters, they were abandoned here(France), never having got off the ground, 2 or 3 years ago, however regs require a set of spare bulbs on board - strange really, the local plods can stop and fine miscreants, but never do judging by the number of one eyed monsters(front and rear) circulating - strange nation!!
                        • duncan
                          • Apr 2018
                          • 137
                          #27
                          Re: MOT
                          That requirement - spare bulbs is what killed the old sealed beam headlamps
                          Shame as back then the headlamps with seperate bulbs used to rust something awful
                            Re: MOT
                            Yep and more.
                            I will check I think he meant the 24hr unless he is going again??
                              Re: MOT
                              My experience in Spain regarding spare bulbs is contradictory. Like spare tyres etc, where the law says you cannot have mimarched tyres on your car but some cars have different sizes front and rear, and then the complication of spare tyre. My Mercedes carries a spare tyre, but it’s uninflated. Once inflated it no longer fits in the boot but it’s a dramatically different tyre type.
                              But to return to bulbs, again on my Mercedes you have to remove the front tyre, remove the inner wing/splash guard just to access the rear of the headlight cluster, but, it is also illegal to work on your car, to change a tyre or even to wash it on the roadside. So every insurance comes with breakdown recovery and you are expected to call them even for a blown bulb, unless you are at home with off street parking.
                                Re: MOT
                                Yep he say's see you there
