MOT
  • duncan
    • Apr 2018
    • 137
    #61
    Re: MOT
    Originally posted by meverett View Post
    Unfortunately not. The upper ball joint can catch on the inner wing if you drive over a speed bump quick.
    I have the dampers that came with my car - bought 23 years ago and never actually been finished
    I had assumed that the dampers had bump and droop stops - do they have the stops inside? - just not positioned right?
    Or does the damper not have stops?
    If it is just a case of position then I could alter the pickup points for the dampers so that they reach the bump stops before bad things happen
      • 2447
      #62
      Re: MOT
      Ok that's around 100 miles on her and the starter motor died.
      Drove (in bmw) to Redditch (160 mile round trip) to get another one.
      Fitted in 10 mins, working fine.
      Been using it as much as possible , using any excuse for a trip out.
      Now up to around 200 miles.
      Day out to see my mate Andy in Chelmsford tomorrow, another 144 miles round trip.
      Would like to put 500 miles on her before Wednesday when we go to Le Mans.
      I agree once it’s on the road there will always be a to do list, change this and that, improve this etc.
      I will probably be a fine weather driver so a heater isn’t important but as I have the vents already cut in to the scuttle I may as well fit at least a fan.
      If you come up with an idea for a bump stop for the front let us all know and so will I. Maybe someone already has.
      Cheers, Martin.
        Re: MOT
        The Marina front suspension with the mini top arm was designed to use Herald or Mk1 Vitesse rear shocks. They had integral bump and return stops. The reason the top arm hits some Marina based cars inner wing is either the original top nut with external bump plate/reaction pad was used instead of a normal nut or the car was set up too low leaving insufficient room for the top arm to move up and down.
          • 2447
          #64
          Re: MOT
          we need to chat. I'll pm you
            Re: MOT
            Phone me if its easier numbers in the mag but not while the GP is on !
              • 2447
              #66
              Re: MOT
              Well that's 144 miles added.
              Chelmsford and back.
              Got a couple of upgrades while visiting my mate Andy.
              Gearstick shortened by 2".
              Fuel pipe to carb re-rooted.
              Both thanks to Andy.
              Trust me to choose the hottest day to take a leisurely drive.
              Car went well.
              Will require a little tweaking.
                • 2447
                #67
                Re: MOT
                Off to Le Mans Classic early on Wednesday .
                Thought I would just give you this link of its first drive.
                  Re: MOT
                  Good luck Adrian, have fun and remember the sun cream.
                  • meverett
                    • 662
                    #69
                    Re: MOT
                    Yes best of luck. Take plenty of pics.
                    If possible keep us all updated.
                      • 2447
                      #70
                      Re: MOT
                        • 2447
                        #71
                        Re: MOT
                        Will try in between the alcohol mist, lol
                        • bryannewell
                          • 331
                          #72
                          Re: MOT
                          Hi Chris
                          If you are not already sorted, I can recommend A1 mot centre at Taunton, I have used them for years and find they are exellent to deal with, They do not do repairs or sell bits so you always get an honest job!
                          Bryan
                            #73
                            Re: MOT
                            Thanks Bryan,
                            Post #52 (which is a long way back!) was about my MOT pass. FYI it was at the Bennet's Field Garage, Wincanton
                            Ta
                            Chris
                            • bryannewell
                              • 331
                              #74
                              Re: MOT
                              Sorry Chris
                              In France at the mo so have not been keeping up with things
                              Missed the outcome post! (no wonder I thought the thread hd been hijacked)
                              Glad you are sorted
                              Bryan
