DRL152K Marina based roadster rebuild
    • 1644
    #136
    Excellent workmanship!
    • martinclan56
      • Feb 2020
      • 486
      #137
      I have modified the reverse mechanism for use with my remote gearchange. Not my idea - I copied it from someone else that had already done it.
      It involves fitting a spring to the reverse lockout plate so it can be pushed to one side instead of having to lift the gearstick to clear it. Seems to work! But only time will tell how good it is in practice.
      gearbox_mod3 by Robin Martin, on Flickr
      gearbox_mod2 by Robin Martin, on Flickr
      And I have pretty much completed the transmission tunnel and floors now. The floors are bonded in using Sikaflex 522 for strength and waterproofing. Should easily outlive me!
      And I trial fitted one of the seats. Err - it didn't fit - too wide. But a bit of attention with some ratchet staps has sorted that. And there is plenty of room between the seat base and the larger than normal steering wheel that I plan to use. My extra depth doors should allow relatively easy entry and exit - I hope...
      seat_trial_fit by Robin Martin, on Flickr​
        #138
        Hiya
        Yep that was my idea and I can confirm that after 3 years it is still working fine.
        Well done, I really am enjoying your blog.
        • martinclan56
          • Feb 2020
          • 486
          #139
          Thanks Adrian. A combination of poor memory and too much internet searching meant I had forgotten where the original idea came from.
          I made the "device" from a short length of 1/4" silver steel, threaded at one end and a boss (from ebay) on the other. Fairly easy to do with just hand tools. The spring in the pictures is a bit too strong so have ordered some weaker ones from ebay. They take 3 weeks to arrive though as they come straight from China!
            #140
            Yep I had to play around with a number of springs but still happy after all these years
            Keep up the log, really enjoying it
              #141
              Originally posted by andyf View Post
              I would consider using grease. I've swapped mine to grease and it seems to be doing fine
              Hi Andy, what grease did you use on your steering rack and how did you get in the rack.
                • 930
                #142
                Hi Adrian, I just took the steering rack gaiters off, and smeared the grease along the rack having turned the steering to full lock, focusing on the teeth. I use bearing grease.
                  #143
                  Thankyou
                  • martinclan56
                    • Feb 2020
                    • 486
                    #144
                    Some good progress now as I have stopped going on holiday for a while....
                    I have now fitted the seats on sliders from Car Builder.
                    runners by Robin Martin, on Flickr
                    The sliders are nice and robust if a little primative. The main problem is the adjustment mechanism projects above the face of the slider to which the seat mounts. They do supply some little spacers but I didn't fancy the whole weight of the seat and it's occupant being taken on just the 4 mounting points. So I made some spacers, that will support the whole length of the seat, from aluminium box section. This also allowed me to compensate for the fact that the seat mounting centres were at 300mm but the sliders could only accomodate 285mm.
                    Before I could fit the seats I had to - err - adjust them as they were about 1cm too wide.
                    seat1 by Robin Martin, on Flickr
                    Now they are fitted you can see there is plenty of room between the seat and the steering wheel to get legs in. I might even fit some seat pads :-)
                    seat3 by Robin Martin, on Flickr
                    The holes in the seat which provide strength (and look pretty) were a bit sharp on the edges. I ran a flap wheel arround them but for the seat belt holes I decided to fit some rubber U strip. This stuff is now available on Amazon and even includes an adhesive strip on the inside making fitting a doddle.
                    seat5 by Robin Martin, on Flickr
                    Next major job is to work out how to fit the front cycle wings....​
                    • martinclan56
                      • Feb 2020
                      • 486
                      #145
                      I have made and fitted the front cycle wing mounts. The wings themselves were intended for the rear of a "fat boy" motorcycle and are made of steel. They look the part having a bit more style than trailer mudguards I have seen used.
                      cycle_wings1 by Robin Martin, on Flickr
                      I put a lot of effort into getting everything square and at the right height. I even temporarily disconnected the suspension torsion bar so I could move the suspension up and down to check clearance.
                      cycle_wings7 by Robin Martin, on Flickr
                      cycle_wings8 by Robin Martin, on Flickr
                      The wings stays are made from thick wall (2mm) tube. I wanted them to be weld free as this is where failures tend to occur. It's a pretty tough to bend. In the end I packed them with dry sand and heated them to cherry red at the bend points. The bends are pretty good with no sign of the tube wall collapsing.
                      cycle_wings3 by Robin Martin, on Flickr
                      cycle_wings4 by Robin Martin, on Flickr
                      The wire you can see is for the indicators which I intend to mount on the wings - somewhere...
                      I fitted the wings themselves with some pretty substantial mounting plates both riveted and bonded in place.
                      cycle_wings5 by Robin Martin, on Flickr
                      Everything is pretty strong. You could (almost) sit on them!
                      Next job - headlight mounts.​
                      • phild
                        • 128
                        #146
                        Its looking very good Phil D
                        • martinclan56
                          • Feb 2020
                          • 486
                          #147
                          Next job is/was to make the brackets for the headlights. There is a lamp bar normally but because of the cycle wings I don't have this. Instead I reckoned the headlights could be supported by the top of the suspension towers. I struggle to visualise stuff in 3D and there are some angles involved so I made a prototype out of cardboard.
                          headlight_mount1 by Robin Martin, on Flickr
                          Now to convert the cardboard into steel.
                          bracket2 by Robin Martin, on Flickr
                          I have discovered the hard way that 3mm steel is pretty difficult to bend neatly so now I slit it half way through the thickness and with a bit of heat it bends perfectly.
                          bracket3 by Robin Martin, on Flickr
                          bracket4 by Robin Martin, on Flickr
                          The bending produces a groove which I then weld up to return the full 3mm thickness. It works pretty well and i have used this technique several times now.
                          Test fit of the bracket in situ.
                          bracket5 by Robin Martin, on Flickr
                          I was really lucky with these headlights. Bought from another Marliner who had purchased them several years ago and didn't use them. They turned out to be actual chromed brass unlike the ones available now which are polished stainless and don't look quite right IMHO.​
                          • MOC Chair
                            • Dec 2022
                            • 224
                            #148
                            Looking good. I really like the mudguards also. It may not be easy to achieve but it would look good with matching ones at the back.
                            • martinclan56
                              • Feb 2020
                              • 486
                              #149
                              They would look good. But currently I have chosen the easy and cheaper route re-using the original fibreglass rear mudguards.
                              • martinclan56
                                • Feb 2020
                                • 486
                                #150
                                The last couple of brackets, for while I hope, are to fit the number plate. I never liked the number plate under the bumper and so have gone for a rectangular plate mounted to the rear chassis leg with a bit of support on the body tub. Bit of a phaff to make but I am pleased with the result.
                                As a bonus - I have been trying to think of a good way to mount the statutary rear fog light. Again I don't like the below bumper position commonly used. Apart from being rather vunerable I also think it is rather low to be easily seen. Having made the number plate mount it also provided an idea position for the fog light :-)
                                plate_1 by Robin Martin, on Flickr
                                plate_2 by Robin Martin, on Flickr
                                I've mounted the number plate using some of those new fangled (lol) bolts incorporating a little LED. They look good but whether they provide enough light to illuminate the number plate remains to be seen...
                                plate_4 by Robin Martin, on Flickr
                                Next step is to fit the hood. There is already a bit of a saga with the unused but trial fitted hood that I bought for rather a lot of dosh. Watch this space to see if I manage to resolve matters....​
