DRL152K Marina based roadster rebuild
    • 2448
    #151
    Originally posted by martinclan56 View Post
    The last couple of brackets, for while I hope, are to fit the number plate. I never liked the number plate under the bumper and so have gone for a rectangular plate mounted to the rear chassis leg with a bit of support on the body tub. Bit of a phaff to make but I am pleased with the result.
    As a bonus - I have been trying to think of a good way to mount the statutary rear fog light. Again I don't like the below bumper position commonly used. Apart from being rather vunerable I also think it is rather low to be easily seen. Having made the number plate mount it also provided an idea position for the fog light :-)
    plate_1 by Robin Martin, on Flickr
    plate_2 by Robin Martin, on Flickr
    I've mounted the number plate using some of those new fangled (lol) bolts incorporating a little LED. They look good but whether they provide enough light to illuminate the number plate remains to be seen...
    plate_4 by Robin Martin, on Flickr
    Next step is to fit the hood. There is already a bit of a saga with the unused but trial fitted hood that I bought for rather a lot of dosh. Watch this space to see if I manage to resolve matters....​
    You could use the LED bolts that I used to light the number plate
    https://www.amazon.co.uk/Kinstecks-Waterproof-Motorcycle-Motorbike-ATV-Cool/dp/B07WW57TQ6/ref=asc_df_B07WW57TQ6?mcid=114d3e353d313157948df54 87776cb0b&tag=googshopuk-21&linkCode=df0&hvadid=696452133743&hvpos=&hvnetw = g&hvrand=11416393347205419196&hvpone=&hvptwo=&hv qm t=&hvdev=t&hvdvcmdl=&hvlocint=&hvlocphy=1006798&h v targid=pla-1042960579872&psc=1&gad_source=1
    • martinclan56
      • Feb 2020
      • 485
      #152
      I have been trying to come up with a way of mounting indicators on the front cycle wings. The problem being the centre ridge, which adds strength and character, is, err, in the centre right where such an indicator would be mounted. After dismissing several idea I decided to bite the bullet and see if I could flatten the ridge at the point the indicator is to be mounted. My main concern is that it would distort the rest of the wing.
      Firstly I drilled a 10mm hole rignt in the center through the ridge.
      front_ind_1 by Robin Martin, on Flickr
      I then tightened a large bolt with several thick washers and a nut through the hole. Of course nothing happened.... The wings are 1.5mm thick steel after all. So I heated up the area arround the hole to red hot using a blowtorch and then tightened the bolt. Hey presto!
      No pictures I'm afraid as I neeeded three hands just to hold the blowtorch and tighten the bolt. But here it is after.
      front_ind_2 by Robin Martin, on Flickr
      And with the indicator fitted. Success!
      front_ind_3 by Robin Martin, on Flickr
      Next post will be hood fitting but is causing me some serious problems so could be a while....​
      • martinclan56
        • Feb 2020
        • 485
        #153
        Just a little side project while I ponder a couple of problems that have arisen while fitting the hood.
        I had acquired a new old stock Vauxall Viva radiator which Marlin originally suggested. But the more I looked at it the less I thought it was up to the job. So a lot of Googling later I came up with a Datsun 1200 radiator. Almost the perfect size and the connections in the correct place. It seems that the Datsun 1200 was very popular in Australia which is Ebay suggested it was coming from. I suspect it was made in China though and came to the UK via Czechoslovakia! Anyway, hand in mouth I offered it up and it fits a treat. It is a heavy duty version with three rows and looks much more up to the job. Not much room between it and the steering rack however but there does seem enough room in front to fit a pusher fan.
        radiator1 by Robin Martin, on Flickr
        radiator2 by Robin Martin, on Flickr
        radiator3 by Robin Martin, on Flickr​
        • Ye Ol Ripper
          • May 2016
          • 297
          #154
          Hi Robin. Looking at your radiator brackets where it appears that you have drilled into the horizontal chassis rail. I note you have used stainless fixings. Did you use aluminium rivnuts? Upon final assembly ,Did you lay the bracket down on a bead of silicon or made a rubber gasket?
          Just thinking & raising thought before final assembly to ensure water doesn't get inside the chassis, which could happen if you are unintentionally forced to Wade/drive through a large puddle / water logged road. I would also inject waxoyl or dinitrol through those 4 holes possibly ising a syringe if the probe tube is too big.
          • martinclan56
            • Feb 2020
            • 485
            #155
            They are steel rivnuts. I put a big blob of paint in the hole before fitting to seal them and hopefully stop any corrosion.
            • martinclan56
              • Feb 2020
              • 485
              #156
              Hood fitting
              I have completed the hood fitting.
              I bought an old hood that had been trial fitted but never actually used. As you can see from the pictures the protective paper over the see through bits are still in place. New hoods are not available and getting one made from scratch would have cost as much as the car!
              You can see that the hood is patinated which I like. Not going for the new look....
              However it has proved to be a challenge....
              1. Although it had never been fitted, the hood had been (badly) glued to a cant rail and at some point mechanically removed leaving the glue that looked like it had been applied using a trowel. There were also some little tears in the inner layer which was not good news. So first job was to remove glue and try to repair the tears. I managed that but it took a lot of time.
              2. The little tabs that are used to secure the hood to the cant rail were missing. I learnt how to saddle stitch and made some new ones.
              3. Now to the biggest problem. The hood was made from double duck. It's the sort of stuff normally used on vintage cars and not really suited to the Marlin hood design. This is made from two layers of cotton with a rubber membrane in between. It doesn't stretch. At all. And it is very, very stiff. I had to make several small mods to make it fit. Again the saddle stitching came in handy.
              Finally I could fit the hood. I stretched it into place using a clamp arrangement and a ratchet strap as I didn't have a helper. It was only 5 degrees in the shed! This worked well. Glued, once again, onto the cant rail using a high temperature industrial strength impact adhesive.
              It's good and taught. The side screens are not quite so good a fit looking a bit baggy. But should keep the rain out!
              Pictures :-)
              hood1 by Robin Martin, on Flickr
              hood2 by Robin Martin, on Flickr
              hood3 by Robin Martin, on Flickr
              hood4 by Robin Martin, on Flickr​
              • martinclan56
                • Feb 2020
                • 485
                #157
                And another little update.
                I needed to de-grease the clutch housing (bellhousing) which, as ever with any British car from the 70's, was covered in a thick layer of old oil, worn clutch lining and road dirt. 3 or 4mm deep in places.
                I thought I would try the new Gunk Ultra which is:
                A - cheaper
                B - more eco-friendly
                It seems to be detergent based rather than solvent based. Well it does work. But requires a lot of scrubing rather than the solvent based Gunk which was very much paint on and then wash off.
                One of the big bonuses is that it doesn't smell! Anyone who has used the original Gunk will know what I mean.
                bellhousing1 by Robin Martin, on Flickr​
                  • 2448
                  #158
                  Keep up the good work, it will be great to see it on the road again.
                  If you want a Tonneau, check out my post regarding hoods and tonneaus.
                  • martinclan56
                    • Feb 2020
                    • 485
                    #159
                    I will be looking for a tonneau so will keep that in mind. Cheers.
                    • martinclan56
                      • Feb 2020
                      • 485
                      #160
                      This is absolutely the last thing that I will do now before moving the car from my man cave to the garage to fit the engine.
                      I chose and fitted a Spal push fan to assist the radiator in its job. They are relatively expensive, but as they say, you get what you pay for and much cheaper than a new engine! There are unbranded fans arround for as little as £20 but I came across a comparison of a cheap fan against the Spal - there was no comparison!
                      The spal fan is also only 50mm thick making it a perfect fit in the Marlin nose.
                      radiator4 by Robin Martin, on Flickr
                      radiator5 by Robin Martin, on Flickr​
                        • 2448
                        #161
                        That looks perfect.
                        • martinclan56
                          • Feb 2020
                          • 485
                          #162
                          It's been a while since my last post but things have moved on. The Marlin has moved from my man cave to the garage (thanks to help from Peter) ready for the engine installation. And I have a real wheel in each corner. Just waiting for the inevitable few forgotten items to arrive now and the engine will be ready for fitting. In the meantime I have been fixing the Pembleton (see my other build) and have started painting the body - pictures to follow.
                          in_garage2 by Robin Martin, on Flickr
                          in_garage1 by Robin Martin, on Flickr​
                          • C_Bogue
                            regular forum contributor
                            • 29
                            #163
                            Robin, your build is exquisite in every detail. A real credit to your skills and vision! Can’t wait to see the finished article. Quick question if you don’t mind! What have you used for your bonnet/scuttle rubber tape and where did you get it from? Thanks and keep the post coming!
                            • martinclan56
                              • Feb 2020
                              • 485
                              #164
                              Thank-you :-)
                              The flat rubber tape is similar to the original. It was a while ago I bought it but I think it was from woolies-trim.co.uk.
                              • martinclan56
                                • Feb 2020
                                • 485
                                #165
                                With a little help from a like thinking friend the engine complete with gearbox is now fitted. 4 hands and 2 heads are better than 2 hands and 1 head! I first tried mating the engine and box on my own and failed - it is a heavy old lump.
                                Everything pretty much fits as it should other than:
                                1. I am a bit concerned about the clutch operating lever which doesn't seem will have much travel. About 2.5cm before it hits the gearbox. Don't think I cocked anything up but it does seem a bit "not right". See picture.
                                2. And the gearbox just touches the transmission tunnel side in one place so a little fettling will be required there.
                                Both the steering shaft and the alternator (not in picture) are fine with a huge 1cm clearance :-)
                                engine_in1 by Robin Martin, on Flickr
                                engine_in2 by Robin Martin, on Flickr
                                clutch_lever by Robin Martin, on Flickr
