leaf spring disassembly
  • kolmershlagjp
    • Dec 2015
    • 180
    Re: leaf spring disassembly
    so if I understand correctly the two plates take the leaf springs in sandwich ?
      Can you take a picture from the rear like my one so I can see the shock absorber mounting.
      Thanks
        Hi
        Below i have included the detail from the Marina manual.
          • 930
          Yes that's right, what I didn't realise was that they are supposed.to sandwich the wedge as well.
          • kolmershlagjp
            • Dec 2015
            • 180
            #20
            photos
              #21
              Some marina's (mine being one of them) didn't have the top location plate. See diagram below. The lowering blocks supplied have a 3° taper to replace the steel wedges
              Here's mine
              [ATTACH]12124[/ATTACH]
              • kolmershlagjp
                • Dec 2015
                • 180
                #22
                Should I keep the montage like in my photos?
                • kolmershlagjp
                  • Dec 2015
                  • 180
                  #23
                  Superflex rear leaves Spring ** version of longer springs improved
                  It must be cut for plates?
                    #24
                    Do you need the lower plates?
                    • kolmershlagjp
                      • Dec 2015
                      • 180
                      #25
                      do not cut the SuperFlex?
                        • 930
                        #26
                        I think the plates are used to wrap the rubber to make it stiffer. In what way would they need cutting to fit?
                          #27
                          I only ask because I have a pair if you need them.
                          • kolmershlagjp
                            • Dec 2015
                            • 180
                            #28
                            no thank you
                            • kolmershlagjp
                              • Dec 2015
                              • 180
                              #29
                              excuse me I do not express well in English
                                • 930
                                #30
                                I have the same superflex bushes and yes they are longer than the original so I would probably trim them to be the same length as the plates as the overhanging rubber at each end will provide no benefit. I suspect that they are actually universal and can be used in several applications as they look similar to Mk1 Cortina bushes.
