leaf spring disassembly
    • 929
    #31
    Re: leaf spring disassembly
    On a slightly different tack. When I took the carpet out I found that the floor board fouls the front leaf spring eye bolt. The last time I was there 25 years ago I hacked at the floor board a bit to get the nut off. Has anyone got a better solution??
      I remember that, memory is a funny thing isn’t it.
        • 929
        #33
        I pulled the Ubolts and saddles from the read suspension last night...
        This is how the Marina Ubolts compare to the Escort ones...
        They are a very close match. Now I need to make a final decision on how to add the anti-tramp bars
          • 2790
          #34
          Andy, from experience (!) it's worth a careful crack check around the holes on the top and bottom plates, and the shocker
          attachment plates as well, though yours all appear to have lasted very well
          Rgds DC
            • 1641
            #35
            Hi Andy. As a separate issue it is good practice to fit a washer on the handbrake clevis pin before fitting the split pin. A liberal smear of copaslip grease during assembly is a good idea too. Peter.
              • 929
              #36
              Rgds DC
              Yes, I was surprised how good they seem to be. They will all get a good clean up and repaint. I'm considering adding a reinforcing plate to the top of the shock mount to fit the end of the anti-tramp bar...
                • 929
                #37
                I'm going to bin the saddle pads as they don't fit and it's recommended not to use them on performance cars as it improves the axle location.
